2oldnslow
Oct 15, 2014Explorer
skipro3 wrote:
One other thing I wanted to point out about that Sun Saver MPPT. It has a MAX output load rating of 15amps. My camper has motor driven jacks. They draw almost 30amps when lifting the camper. Because of that, this controller would not work in most campers with motorized jacks.
The solar controller controls the charge current from the solar panel into the battery. It does not matter what current your jacks draw, that current does not go through the controller. Or should not.
The LOAD output is typically not used in an RV application. It is used for sign lighting and other untended remote applications.
