camp-n-family
Aug 28, 2017Explorer
You're going to be limited by your trucks' payload which unfortunately won't be enough to carry much of a tongue weight once the seats are filled. Toy haulers have high tongue weights to counter the garage weight in back so even the lightest trailer will push 1k which in a half ton will only leave a few hundred pounds for passengers and stuff. I can guarantee you won't get anywhere near a 40'er without a bigger truck. Forget the magical tow rating number as well. You will far exceed the payload, tire , and axle ratings before getting anywhere near it.
I'd suggest loading your truck with passengers and gear as you would normally expect to travel and go to a scale. Subtract that weight from your GVWR. The number you have left is for the trailer tongue weight and the hitch. Figure 75lbs for a good weight distributing hitch, that you will need, and approximately 15 percent of the loaded trailer weight as tongue weight. It'll be a small trailer with mostly garage area. This is only 18' and if you look at the specs it would probably push or exceed your trucks limits unless it was just you in the truck and everybody else followed in the Traverse.
44,068 PostsLatest Activity: Jun 09, 2026
