wanderingaimles
Oct 18, 2017Explorer
Is not always reaching 100% daily really an issue? Are you out for long periods during the fall when days are shorter and the sun is lower?
If you are only down to 70% after overnight use, and the charge brings you back to 85%, after the second night you would theoretically be down to 55%, but when the sun came up that day, your charge rate should be higher since you wont be encountering the "topping off" phase. It may well be able to return you to 85% daily.
Have you stayed out long enough to see if you reach a point where the panels keep up?
44,057 PostsLatest Activity: Mar 12, 2026
