hedge
Oct 18, 2017Explorer
I think you must have your panels wired in parallel if you are using a PWM controller. Also based on the observed amp ratings.
I don't see that you mention what draws you have. I also have 3 100w panels and I'm usually back full by 10-11am in full sun. My uses are small though, mostly just to make coffee in the morning with my inverter/Keurig. In early spring or late fall some furnace use. I've never had a problem getting back to full. I have a Victron 700 monitor but I can't remember what I have the 'full' detection set at.
44,057 PostsLatest Activity: Mar 12, 2026
