I’m looking at the RecPro 9.5K low profile A/C. I have never heard of them. Does anyone have any experience with them, or heard anything about them? Thank you. https://www.recpro.com/rv-air-cond...
Hello, Jim. I tapped into the hot line at the ceiling ac box with my multimeter. Just took the wire nut off and attached the red to the line side and black to the work side. I have to review the procedure to check volts. I put the black on the ground wire, and the red on the hot wire. Was reading .060. I was assuming that was not right. I have a UNI-T clamp meter arriving Wed from Amazon. I will run the numbers with that when I get it, and also run it on the 2000.
