Um, a 2000 watt Honda is going to be working at a pretty high wattage rating. Think Honda recommends 1600 continuous watts max.
The ratings for cooling is a bit confusing.
Rated curent for cooling of 12.6 amps = 1512 watts using ohms law.
Note what they say, "Input needed for cooling is 1370.".
They way I look at it the 2000watt honda will be working pretty hard. Probably the 2500 watt unit would be better. The 2000 generates a max 16.6 amps. I would bet that at altitude the honda 2000 could not handle the needed max current of 14.6.
Another issue is the remote only controls..
I do like the unit though.
Jim
Recpro AChttps://www.recpro.com/rv-air-conditioner-low-profile-9-5k-quiet-ac-with-remote-control-non-ducted/?gclid=Cj0KCQjwzYGGBhCTARIsAHdMTQwgeeWSvRSXalwlyR4YoVDGHmbnFjuTfjXUy0wUnFHApZ9eopcbQMwaAvnMEALw_wcBPower supply: 115V/60Hz
Refrigerant charged: R410A/430g
Rated cooling capacity: 9500BTU/H
Input needed for cooling: 1370 W
Rated current for cooling: 12.6 A
Maximum power input: 1590 W
Maximum current: 14.6 A
Energy Efficiency Rating (EER): 5.97
Maximum design pressure: 600PSIG
Minimum design pressure: 236PSIG
CFM (high speed): 235
Installed weight: approx. 68 pounds
Recommended for space up to 400 Square Feet
Recommended wire gauge: 12 AWG or larger
