Reddog1 wrote:
I use the gray water as a pre-rinse, not really necessary to use the freshwater, but my preference. If I dump at a dump station, I usually do not use the freshwater.
At home when I dump, I rinse my tanks each time I dump. I will run several gallons of fresh water in each of the tanks several times, and dump. I think it helps reduce the likelihood of solids build up in the tanks. It does not require much effort, just a little time.
I agree.... if you ever have a plugged up or full black tank to work on you'll keep your own campers tanks clean from then on. It just take a little while to do it correctly.
As far a 110VAC units... thats for people that camp in campgrounds that don't have hook ups for their sewer hose... Inverters are pretty expensive to pump ****
