So we upgraded from a 26Ft to a 37Ft TT and we have lots of sway now when windy or passed by a semi. We are currently using a WD system with a friction sway bar. We were wondering if we should switch ...
The Dual Cam will help. First I would also play with adding more tension on the spring bars. You wan't to stop the sway from starting in the first place as much as controlling it afterwards.
You could also weigh the tongue and make sure the bars are sized right.
