Others may give you a better idea but I have some old tooth brushes to clean areas like that. When the burner is cold, brush the orifice and it will remove a lot of the growth around the pilot. You can get a wire that goes in the orifice as well, make sure that it is the correct size (propane). I have also used canned air BUT again when shut off!
