wwest wrote:
Are you saying that the heated air from the burner/element is being diverted by the A/C draft, the absorption manifold above the burner/element is not being heated when the A/C is on?
Electric element is only 150 watts....
Something about the A/C is WRONG!
The A/C should NOT be causing that much of a "vacuum" inside the trailer.
The only thing that comes to mind is the possibility that the evaporator blower is somehow forcing airflow into the wild blue yonder.
Think what OP is saying...
Fridge is not properly sealed so that when his A/C Unit comes on is it pulling air in around the fridge..this is causing a disruption in the natural draft across the backside of fridge cooling coils. Hence instead of the air flowing in thru lower fridge vent and then up across coils and out top vent it is being pulling in around fridge.
No flow up and out.......loss of cooling effect.....fridge temps rise.
