wildtoad
Aug 15, 2016Explorer II
Read your owners manual for your wh. It may suggest you drain it between trips. If you have an anode rod then perhaps you should do this...
"To extend anode life, drain water from tank whenever RV is not being used. Avoid any extended time of non use with water in tank."
44,066 PostsLatest Activity: Apr 16, 2026
