d1h
Oct 21, 2020Nomad III
Regular or premium
I know that Chevy recommends premium gas in the 6.2L engine. What do all of you out there use? Is using regular a bad idea?
noteven wrote:
Modern auto engines do not ping - knock detection adjusts timing and fuel to prevent any pre-ignition or detonation.
So when you buy an engine that is designed for 91 and you use 87 or less in it will run fine. It is not producing the power you paid for is all. Sometimes the vehicle will use more 87 per mile than 91, especially if you are tow / hauling and actually using max power.
