ArticFox_676's avatar
ArticFox_676
Reinforce bumper
Previous discussion about reinforcing the rear bumper someone posted pictures of a bracket to add strength to the bumper. I can't find this picture and don't remember the name. Can anyone point me in the right direction? My searches turned up nothing.
  • I need and will be putting a hitch rack on my TT, it is a 2017 new, but I have already had the rack mounted and with me ( 205 lb ) standing on it and jumping it does flex the thin bumper tubing, so tonight I will be cutting it off and welding an 8 ft 1/4 in wall tubing bumper on with some gussets, I trust my welds more than a factory job anyway, my frame is heavy tubing that extends to the bumper so no worries there.
    I would have never though about giving it a good inspection without all this talk of them beeing weak.
    so thanks for that.
    then I will weld a plate on and on that weld on a 2 inch reciever, our bikes will be safe on that I would think.
    I will weld the original bumper under the new one for the poop tube storage.
    I also checked the tires and axle raiting with the max GVW of the trailer.
    trailer says 7540 max, 5170 dry, I have 3500 lb axles and the tires are 1,540 each x 4 so I will upgrade tires when I replace them.
  • Thanks for all the choices. Hide a spare sounds interesting. Will look into these options.
  • The under body spare tire mounts may be fine and certainly are popular, until you need them and find them rusted shut.
    That happened to me and I ended up cutting the cable and placing the spare in the truck bed.
    On my present TV I crank down the spare and grease the cable in the spring.
  • I bought a 'spare tire winch' from a pickup truck and mounted it under the front of the TT with the rod that turns the winch up and down out the front so I can crank it up and down with my cordless drill... I'm pretty sure there is a after market model you can buy... no weight on the bumper..
  • I reinforced my bumper... I extended it 30" and mounted my generator box back there...
    I spoke with the insurance company... no problem..
    You do have to distribute weight forward to offset the added weight on the rear...
  • ArticFox 676 wrote:
    Thank you for the link. That is just what I needed.
    Sorry to start a problem. This is for our trailer bumper. Want to put a second spare on the bumper. Just using caution.
    How about a Hide-a-Spare?
  • Thank you for the link. That is just what I needed.
  • I honestly dont think anyone one will care if you reinforce your bumper. I did it ages ago because my bike rack tried to rip it off.
  • For what purpose do you need to reenforce the bumper? Manufacturer could claim all kinds of things in a collision injuring you or a passenger or bumper failure injuring others. The vehicles we drive are not Model Ts. You may be messin' where you shouldn't be a messin'.
