tmartin000
Jun 19, 2016Explorer II
SoCalDesertRider wrote:tmartin000 wrote:I'm a skilled aluminum welder and fabricator and like to work with aluminum, however, galvanized steel works just as well or better in coastal environments and is alot less expensive to build with than aluminum and doesn't have the cracking problems of aluminum when used in a structure that is subject to loading, twisting and vibration.
I live near the ocean, aluminum is the only material I will consider.
Thank you for that. So, if it's galvanized, I should be good?
Looking online for aluminum truck beds revealed some gorgeous boxes. I just figured that I wanted aluminum.
44,067 PostsLatest Activity: Jun 05, 2026
