covered_wagon
Jun 20, 2016Explorer
drc5900 wrote:covered wagon wrote:
Oh yes, the fuel fill is lower down so it's sometimes more difficult to fill with fuel because a lot of them tend to shut the nozzle off frequently. I solved that a couple ways if any are interested I can explain.
I am interested to learn how you solved that. Kindly please explain!
Pro Tech used the oem filler neck which most have an anti siphon hose blocker down the end of the pipe. Pull the fill neck/pipe and cut out the anti siphon hose blocker. Fuel will flow much better into the tank. The other thing you can do is throw a block of wood down to drive over and tilt the bed a little bit, but, I've never had to do that.
I must say one last word about Aluminum... Pro Tech has the most beautiful designs and does not weld key areas but are riveted very strong. I've had my Pro Tech bed for almost 20 years and no problems. Everytime I go in there for new weather stripping to be put on the saddle tool boxes or new locks cause they wore out, they will not let me pay them. They are good people and are the most successful in the industry. They do the fire trucks and ambulances.
44,067 PostsLatest Activity: Jun 05, 2026
