Bedlam
Jun 20, 2016Moderator
Torklift now has the GlowStep Revolution for trailers and side door TC's. When I get my triple, I will converting my GlowSteps with the Revolution mounting hardware. My buddy's Mammoth on a F350 even needs an additional foot stool step to get in, so the problem is not limited to your Chalet.
WA also looks at enclosed trailers over 10K lbs as commercial. They downgrade the rating on the trailers going to the state to save the buyer. Once you get to the large triple axle models, you're on the hook for commercial unless you add enough living quarters to call it an RV (you then get an exemption to the weight limit). My trailer is running dual 5200 lb torsion axles with newly upgraded 2805 lb rated tires and rims, but is still tagged under the 10K lb limit.
44,067 PostsLatest Activity: Jun 05, 2026
