CAJW
Jun 19, 2016Explorer
Pretty tricky to do I'm told, but can be done. You should look at the battery tray first to see how that is removed, the "Joey" drawer is the same principle, albeit on a larger scale. You'll need to pull it out 6-8"? to line the rear rollers (at the front of the camper) up with the cut outs in the track. Then using a lever and fulcrum you'll need to lift the rear (again, the rear of the drawer being at the front of the camper) of the drawer to lift the rear rollers out of those cut outs and slide the drawer out. I got this advice from my dealer when I had some issues with the drawer not sliding easily, but some shimming at the access door end fixed it so I didn't actually have to remove it. Good luck!
44,056 PostsLatest Activity: Nov 19, 2013
