Roadtech's avatar
Roadtech
Removeable Mud Flaps
I need to buy some mud flaps for my 2015 Chevy 2500 HD Duramax. I want removeable ones and I like the ones that mount on the hitch, but I am having a problem finding ones that will work with my 2" Hensley Arrow hitch into a 2 1/2 to 2" receiver adapter. I called Rock Tamer and they say I need a minimum 1 inch of stinger from the face of the receiver. My stinger is a dropdown type and the part of the stinger that drops down is right up against the receiver. What other good ones might work. Also, I need to work around the large diesel exhaust pipe at the rear.
  • You could weld a second 2" tube under the real hitch. Use it for the hitch mounted mud flaps.
  • I keep thinking about a removable set myself, so please post up what you decide to buy (or make if you go that route).
    One hang up I have also is the darn exhaust out the back corner. I have even considered making a mount that attaches to the hitch, and use a pin to secure the mud flap "bar". While it wouldn't work with your Hensley, I have even consider making one that attaches to the bottom of the drop shank, below the hitch head.
    Between protecting the front of the tt, and keeping road slop off the front of the clamshell snowmobile trailer, need to figure something out!
