saltfevrExplorerNov 03, 2014removed bypass valve. now no hot water?I replaced a leaking valterra 1/2" rubber hose with pex and sharkbites. Removed plastic factory 3 way bypass with brass sharkbite t. Now no hot water. Me thinks i messed up? Guess that vslve serves mo...Show More
mhardinExplorerNov 03, 2014Yup! The bypass valve must be normally closed for hot water. Replace it and you should be back to normal.
Related ContentStaple RemovalWater Heater bypass valve.Replacement furnace valve? Removing valve?bypass valveWater Heater Bypass Valve - How To Replace
