Old-Biscuit
Nov 04, 2014Explorer III
Bucky Badger wrote:Old-Biscuit wrote:
That 3 way was a cold water inlet AND the bypass depending on which way valve was turned.
Did you replace it with another 3 way valve??
NO, he replaced it with a "T"
If a 'T' was installed then water heater is probably still empty cause water would flow up thru bypass line and back against check valve in hot outlet so very little water would flow in thru cold inlet due to check valve being closed.
Hope OP fixes with another valve before turn electric on or he'll be replacing element also.
HEY OP.....are you reading/following up??
44,059 PostsLatest Activity: Mar 17, 2026
