memilanuk
Jun 26, 2021Explorer II
Remove/replace onboard generator
Recently sold the TT and picked up a TC.  Already had a nice Honda EU2200 for the TT, didn't really 'need' a camper with an onboard generator but it came with one (Onan 2500 LP).
It seems to run fine... low hours (just about due for it's first 20 hr oil change)... noticeably louder than the Honda, plus the vibration...
On the one hand, it *is* awful nice to be able to just fire up the generator with the push of a button, when needed. No setting up the gen set, running out the shore power cable to it, making sure it's secured when we're not around, no worrying about it getting stolen...
But on the other hand, we don't (currently) use a ton of AC power while camping. The majority - other than the air conditioner - could easily be handled by adding solar, upgrading the batteries, and an inverter/charger, all of which are already on the 'to-do' list. If it's just for the times/trips where we're planning on being some place warm-ish and anticipate needing A/C... then setting up the generator and shore power cable, and giving it a quick pull to start... isn't a huge deal
Honestly, what I'd *like* to have is one of the new Onan 2500/2800 inverter generators - almost as quiet as the Honda, way less vibration than the OEM version, and all the pros of an onboard gen set. I'm guessing those might be a bit spendier than I'm willing to go for, though ;)
If I *were* to pull the Onan 2500 LP gen set out... is there any kind of used market for these things? Better to leave the 'generator pre-wire' in place, or yank it at the same time?
