deltabravo
Jun 26, 2021Nomad
I found a metal supply store that was open today, so I went there and bought some plate aluminum stock and fabbed up some mounting brackets. It's a HUGE PITA to make it work because I didn't want to drill into the base pan of the generator liek Northwood did when they mounted the old skool genny, rather than use the threaded inserts and bolts to mount it.
I should have it installed and running tomorrow, unless I can't tolerate the 110 heat outside
