rhagfo
Apr 25, 2019Explorer III
Huntindog wrote:
TTs are generally built from the inside out. The cabinents go in before the walls and ceiling.
The floor is the first thing that gets installed.
How much do you like this cabinent?
Consider cutting it out, and replacing it.
This mostly depends on the trailer siding.
Aluminum siding screwed on from the outside (mentioned earlier), real PIA to remove.
Fiberglass, attached from inside, might have screws hidden from panels attached after attaching to walls.
