kilboar
Feb 18, 2019Explorer
Westcoasting wrote:kilboar wrote:Lwiddis wrote:
I vote with Ed. Bunch of work for little return.
Thank you,
I thought I knew something about TT but coming from a FEMA TT with a residential toilet and a septic tank I'm used to once I was done with my business and paper work it was gone, never to be seen or smelled again. Using this new TT again as a stationary unit I'd like the same experience and do not want to worry about fumes seeping back inside or dealing with black tank maintenance if I don't have to.
As far as resale, I'll keep the tank and try to make any work I do reversible but I'm not to concerned about the next owner as much as I am the current owner.
My father inlaw has been living in one the last couple years, as far as maintenance... he does nothing other than dump it and put more water back in. Are you sure you might be overthinking things here?
That's highly likely:-)
I may just need to uses it for a while then decide.
Another big reason is I'd like an adult size elongated toilet bowl so my junk isn't one with the inside front of the bowl when in use. This thing looks like I'll be dumping inside a coffee can.
