beemerphile1
Sep 26, 2013Explorer
Don't try to remove the rust unless you have the correct equipment and a ventilated work area. Grinding, sanding, or otherwise removing the zinc plating releases dangerous toxic chemicals in the air.
Use a rust neutralizer and a quality rust covering paint. Rustoleum is an okay consumer brand.
If you want to use really good stuff, get some POR-15.
