anaro
May 18, 2014Explorer
Water conservation..... if you are not at a full hook up you will fill your grey tank very quickly. Take showers at the bath house to save on water and use paper plates to decrease on dishes. If she insists on using the tt shower then take navy showers (get wet, turn water off, soap up and put shampoo in hair, turn water on quick rinse off then get out). If at full hook up, you will just have to open the grey tank periodically. Never leave the black tank open all the time (you should always keep a couple of gallons of water in black tank. Make sure the pull handles are closed before removing the sewer cap.
Use septic safe toilet paper (ie angel soft) and add extra water to the toilet bowl when having a BM. Make sure the rental company gives you the hoses and connectors you need.
Sewer hose kit
White fresh water hose
Make them show you how to use everything. Set the awning to have one side a little lower than the other for water run off during rain. If windy put the awning away or it could blow up over the rv and break. Have fun!
Sewer hose kit
44,056 PostsLatest Activity: May 04, 2014
