eHoefler
Mar 17, 2014Explorer II
When using brake cleaner, you spray and let it run off. Do not wipe it off or spray a rag and wipe with it. Brake cleaner is designed to be sprayed liberally and let the fluid carry the contaminants away. I typically use 2 large cans per wheel cleaning the drum and shoe assembly. After cleaning, DO NOT touch any or the braking surfaces! You will need to re-adjust the brakes after assembly and usually after another 500 miles.
44,029 PostsLatest Activity: Jan 28, 2025
