spike99 wrote:
Inspecting brakes every 7 years???? Scary...
Remember....
There's reasons why many regions are forcing mandatory annual brake inspections on trailers. They are forcing the law because people don't understand the reasons to do it annually. When inspecting (clean and replace worn out parts) brakes, then repack the bearings with fresh grease at same time. Easy DIY task - since hubs are off anyway. And, it saves lives as well...
And when selling your trailer, remember to tell possible buyers you do annual brake inspections and bearing care. Tell them you do it every 7 years and see how fast they run away.... LOL!!!
Why is it scary? Do or did you pull the hubs every year on your TV? Why not? Scary! LOL
What are you going to do when you get a trailer with sealed cassette bearings? How are you going to inspect them?
You do realize that the bearing system is a sealed system don't you? If you use a good quality grease it's there for life. And for all you nit pickers yes I know that "some" inferior greases will separate. I don't use those and my recommendation is you don't either.
I have hubs on my place that are over 50 YO. Pull the hub and guess what? Yep, grease still there. Bearings still there and in good shape.
Remember.......
There's reasons there are states that don't let you pump your own fuel. They are forcing the law because people don't understand how complex and dangerous it is to pump your own fuel!! SCARY!!!!
And it saves lives as well!!......... :B :B
