Roman_Duck
Feb 21, 2014Explorer
Depends on use, nonuse. average would be no more than 2 years or the manufactures specs. When you clean them for pitting inspection do not use gasoline, use kero instead.if you need to replace them, make sure to change the races also. Most inportant is to do regular inspection on the wheel assemblies, including the back side of hub; check the grease seals, make sure they're not leaking.
44,056 PostsLatest Activity: Jan 22, 2026
