coryanderson
Nov 30, 2021Explorer
Grit dog wrote:
Note, I e removed a couple jacks before as well as fixed the bracing in the belly. Just not at the same time. So my suggestions are based on what I know from that. Never had to get to the frame and repair it.
Thanks! It does sit fine with the 4 jacks only, I usually throw 2 pipe jack stands underneath the belly when it's not on the truck, mostly for extra safety precautions to protect kids and dogs.
I think you are right about trying to tear apart the underside first to see what is going on down there. Then I can maybe weld the frame back together which will allow me to rebuild the back wall properly.
I would have done this all sooner but we use this camper all the time and right now is the longest gap we have between current camping plans.
I am really looking forward to being able to use the slide-out again without having to put the right rear jack down. Sometimes you don't realize how good you got it till it's gone.
44,072 PostsLatest Activity: Aug 23, 2026
