coryanderson
May 25, 2022Explorer
JoeChiOhki wrote:coryanderson wrote:
Need some help with what compound/epoxy I should use in this situation. This is the back corner where I dragged the jack. I plan to weld this area together, but 2 lag bolts come through this area to hold the jack in place. I would like to put something inside of the tubing that would act as wood so when I put lag bolts through they have something to grab onto.
Any ideas that would work the best for this situation?
Steel backing plate and bolting through instead of lag bolts.
That won't work. These pictures are from the side, the bolts are actually going from left to right in these pictures. I meant to take more last night and forgot.
I bought this stuff, but I think I need to insert the lag bolts before it dries. Has anyone used this stuff before?
https://www.homedepot.com/p/Quikrete-8-6-oz-Fast-Setting-Anchoring-Epoxy-862030/203604177?source=shoppingads&locale=en-US&&mtc=Shopping-BF-F_D22-G-D22-022_009_CONCRETE-NA-NA-NA-SMART-NA-NA-New_Engen&cm_mmc=Shopping-BF-F_D22-G-D22-022_009_CONCRETE-NA-NA-NA-SMART-NA-NA-New_Engen-71700000082416240-58700006970241162-92700062772249734&gclid=CjwKCAjwp7eUBhBeEiwAZbHwkY9R7b9tCEjAhHIW8XJaaZ2JM0KPOdqsNpVEOXnQCC8WYbEbpn3obxoCwr4QAvD_BwE&gclsrc=aw.ds
