Riley01
Sep 08, 2020Explorer
Repair Help (Sealing)
The instructions warned me but I screwed up anyways when I mounted the storage brackets for the Stablecampers on my AF 1150. They were right, you don’t want to have to remove these. If you ever put these on learn from my mistake and be sure there isn’t any interference. In my case I should have mounted them further towards the outside of the camper. Where I mounted them they came out right above the rails on the truck bed. I was shy about a half inch, now I get to fix the spots (4) where I removed them. That adhesive is some tough stuff.
What would the proper material be to fix these (4) spots? It seems like the paint used is some type of vinyl as it melted pretty easy when I used the heat gun to soften the adhesive.
Thanks,
Rick
Thanks,
Rick
