Photomike
Aug 11, 2017Explorer III
As mentioned the fiberglass is really thin and has no strength in itself. You want to get to the wood behind it and secure to that.
Filling the hole as mentioned above with the wood and glue, put he screw in and you are done. No need to fill the fiberglass hole unless you have a crack that is running as all you are going to do is put another hole in it.
