Ste7of1
Aug 13, 2017Explorer
If you are only dealing with fiberglass (no wood backer to grab) another option would be to install a small rivetnut through the hole. This would grab on both sides then you can use a machine screw into the rivet Nut (sized to match) to secure. This approach does require a rivet tool for the rivet Nut installation. For example: https://www.amazon.com/eBoot-Plated-Carbon-Insert-Nutsert/dp/B01NAHXLJM/ref=sr_1_2?ie=UTF8&qid=1502663312&sr=8-2-spons&keywords=Rivet+Nut&psc=1
If you have access to the backside of the panel you can use a weld Nut instead of the rivet Nut eliminating the need for the rivet tool. https://www.mcmaster.com/#90860A100
