I have an 06 195ck Antigua. Just this year it has developed 2 soft spots in the floor and 1 in the ceiling. The ceiling is from a sky light leak. Will need rubber removed and wood replaced. 1 spot in ...
Thank you all for the input. I am finished the roof. Replaced some wood and all new rubber. Cause was no tape under the shower skylight. Now I'm working on the floor. There is a lot of rot. Both front pass through doors and 1 marker light leaking. No tape under doors. Just a bead of caulk that has failed.
