crossman61
Apr 29, 2015Explorer
LEMII wrote:
A little off topic, but related in a way. I noticed a 2" wide x 10" long x 1/4" tall bubble in the linoleum right in front of the kitchen sink of our 2007 Jayco 23B. I inspected the underside of the floor and could not detect any softness or structural issues of any kind. I don't see any water damage or evidence of a leak under the sink either. So I'm thinking and hoping that it's simply the adhesive loosening up on the linoleum.
Anyone else have a similar issue? What was done about it? I'm thinking about just covering it up with a throw rug.
Thanks.
I have not seen any adhesive under the linoleum that I have removed so far, I also have a ripple like you described near the stove. There is no discoloration there Like I have where the moisture is, so I am assuming the the vinyl flooring has stretched in that area. I'm not sure at this point how much of the flooring I will be replacing, so I may not look under that spot right away.
