CharlesinGA
May 15, 2020Explorer
mrgrim007 wrote:
My 2002 Suburban 2500 has worn/rotted bushings in the leaf springs. Should I get these replaced before we move to a heavier TT? Would it be cheaper or better to just replace the springs (and maybe add an extra)?
Our current TT is 6,000 GVWR and we’re looking at a 34’, 9,995 GVWR.
Thanks
While the exposed ends of the bushings probably look cracked and bad, I'll bet the rubber further in is perfect. If you want to do something, as already noted, get polyurethane bushings if they are available.
Unless you have been hauling heavy loads, the leaf springs are probably in excellent condition. I have seen the 2500 spring pack, co-worker shopped for a year for a 2500 4wd 8.1 combo. Ended up getting one in Austin. That thing is a hauling beast. His is an '05 with the air shock system and 4.10 gears. Hauled a '70 charger on a trailer back from Indiana to Atlanta and said he could not even feel the trailer back there.
Charles
44,071 PostsLatest Activity: Aug 30, 2026
