JIMNLIN wrote:
Some with torsion type axles say the trailer aid type ramps doesn't work with that type suspension.
 Whatever method you use make a dry run at home to see if it works. Out in the middle of no where isn't the place to find out it didn't work.
Trailer Aid works with Torflex axles, it depends on which "start angle" the axle was ordered with. The user has to be smarter than the axle and trailer aid.
Trailer Aid comes in two different versions, standard and plus. The plus version adds an additional inch of lift. In any case a block of 2x10 under the ramp will usually give you enough lift if the start angle of the axle is such that you need it.
If you have a Lippert frame I would suggest not jacking under it unless its an absolute neccesity (as the OP's Windjammer has). They are lucky to stay intact just with normal use. I have used a piece of true 2x4 oak cribbing that spans both torflex mounting brackets when we had a Rockwood with Torflex axles, and wanted to use a bottle or floor jack to get both wheels up at the same time. On conventional sprung suspension a floor jack below the u bolts on one of the tubes. I'd never place a jack under a paper Lippert frame.
