vikigar
Mar 14, 2017Explorer
Thanks for the replies. I have 2" of clearance, top and sides, so larger size should fit. However, the stock rims are 5" and the new tires need min. 5.5" but 6" is recommended. So I will need to buy new rims. The 205 tires are rated at 1760 lbs of load. the trailer is rated at max weight of 3500 lbs, so only 20 lbs of margin of safety. The 215 tires I've selected are rated at 2200 lbs, so 900 lbs of margin and I'm assuming a stronger tire all around. Thanks again for all the input.
