4aSong's avatar
4aSong
Replace the WFCO with an IOTA w/smart charger
I am contemplating replacing the WFCO Converter/Charger model WF-9855 in our 2011 Lance model 1985.
In storage in my shop is an IOTA DLS45 with smart charger that I purchased new and only used it for maybe 1 year, this would be installed in place of the WFCO or should I just keep the WFCO in place until it fails and then install the IOTA.
All inputs on going forth with this would be appreciated.
Thanks a bunch. Mike
  • Replace the WFCO with the IOTA immediately if not sooner.
    If you want a spare get a spare IOTA.
    ebay the WFCO.
  • You do bring up a good point on installing the IOTA as close to the batteries as possible, now I will have to look into this a bit further. I'll check the unit tomorrow and see how much trouble it would be to relocate the converter and breakers closer to the batteries. I was looking to do a swap out and use the existing breakers.
    I do agree that the IOTA is a much better and more efficient unit.
  • I guess I should have said why !!hihi
    Because of charging, even if the wfco is "3 stage" the Iota is much better.
    It push higher amperage longer, and keep it at a higher voltage which deep cycle is all about.
  • I'm in the same scenario, I left the WFCO, but put breaker to off.
    And place the Iota(Whit Smart Charger) as close as possible to battery.
    It's plugged via a receptacle close by, but will hardwire it to breaker.
    Have yet to decide if using a new breaker or completely disable the wfco and used existing breaker.
