aarond76
Mar 20, 2014Explorer
Replacement Flooring Options
We are updating the interior of our travel trailer. This does not seem like a popular option vs trading up, however taking into account the bath we would take on what we have and the high cost of what we would want to replace it with, Updating the interior finishes is the direction we have decided to go.
I am looking at (3) options for new flooring:
1) Interlocking Vinyl Plank - Pro's are water resistant. Cons are heavy, more expensive, don't know how well the joints lock together.
2) Traditional Laminate Plank - Pro's are I have a fair amount of experience installing this at home. It is cheap. Cons are not water resistant, Fearful that one random joint somewhere in the middle of the floor decides to seperate at some point due to the extreme temperature variations in a TT.
3) Loose Lay Sheet Vinyl - I like this for durability and lack of seams. I am concerned that in the extreme heat of summer it will expand to the point that it will not want to lay flat on the floor. Worried about it shrinking to the point of ripping in the extreme winter cold (I have read alot of stories of people opening there rv's after this extreme winter to find the sheet vinyl split down the middle)
What are other's experience with this? I will not be using the Allure flooring that has the glue strips on the edges.
