n0m4d
May 18, 2018Explorer
jimh425 wrote:
Are you sure the top isn't reversible or adjustable?
No, it's all welded together so I don't think there is a way to rotate the head 90 degrees without some grinding and welding. If the bracket was at a right angle to the cranking axis I could see there being a possibility of removing the horizontal bits and reinstalling the 180 degrees so it cranks from the other side. I technically may be able to use them as is if I installed the 2 sames on the rear, it just would look weird and these weren't particularly cheap. I use a drill for up/down but if I had to use the crank in a pinch it probably would interfere with the camper.
