- MM49Explorer
edge_kw wrote:
I bought a BeautyRest mattress from the RV Guy's. They are a couple of retires that got into the trailer mattress business. They special order mattress in the trailer queen size. They order them 250 per order. You pick them up at their rental storage. I am very happy with mineBeautyRest.
Has anyone found a source to replace the stock mattress from a Keystone Sprinter? It's an odd size 65x74. Thanks.
MM49 - HuntindogExplorerSee if you have a mattress manufacturer in your area. I just got a 13" thick innerspring pillowtop made for 211.00 here in Phoenix. It only took 3 days, and the do not remove tag has my name on it.
- majorgatorExplorerWe bought mattresses from the foam factory, as referenced by Old Biscuit. Good quality, great prices, lousy customer service. If they don't have your size, then order something slightly larger and cut it down. That's what we had to do and it worked out fine.
- edge_kwExplorerThanks for the responses.
Yes, I'm sure on the 65" measurement. That's Sprinter's "emperor" bed. - Dick_BExplorercontact www.verlo.com
- darsbenExplorer IIAre you sure on the 65 inch measurement.
There is a size called short Queen that is 60 X 74 - Old-BiscuitExplorer III
- n7bsnExplorerThat's a really odd size. Might I recommend going to a custom foam shop and have one made for you.
