ScottG
Mar 28, 2015Nomad
Not a hard mod but will require you use a few hand tools to mount the new power supply.
The metal box on the left is removed from the bottom of your converter and the old power supply section is removed from it.
The new converter supply (PDI9260) is on the right and will take its place in the metal box.
And here it is installed.
I took this opportunity to install a heavy duty 20A light switch (right of conv.) to be able to turn off power to the converter if needed.
