time2roll
Mar 28, 2015Nomad
As long as you have space behind the panel and easy access to mount the Paramode it will be just as easy as the slot mount PD4600. Although the PD4600 kit comes with an improved fuse board that is available separately if desired.
If you are expecting a fast charge on generator the Paramode is a bit low on voltage. PD actually hits the voltage pretty good for most conditions.
