rottidawg's avatar
rottidawg
Replacement radio with NAV and backup camera?
My 2012 Chevy 2500HD LTZ has the Bose system but not navigation and most importantly not a backup camera (my wife and I seem to fail to communicate). I have a small slide in truck camper mounted pretty much full time so the camera is important and navigation would be nice.
The local Car Toys recommended Kenwood but I will listen to any suggestions. Willing to spend what is necessary for a good system....especially nav and camera. I suppose I could go with the add on systems but I prefer a "cleaner" solution. Anyone running aftermarket head units?
  • Huntindog wrote:
    I have the factory BU camera. It is mounted in the handle of the tailgate.... With a slide in camper, your tailgate is removed, Correct?
    No tailgate = no camera.
    Correct...I have no factory nav or backup camera and no tailgate. Thus a new head unit with navigation and backup screen with a new wired camera mounted either to the camper or rear bumper.
    Or get a license plate camera like this:
    TaoTronics TT-CC17.
    Mine is hard-wired. I bought 2 4-flat trailer wire combo male+female connectors from Walmart and built a 3 1/2 foot extension cord for when the camper is on. When it is off I remove the extension cord. It's all custom wired with 2 wires going to power and 2 to video, and the connectors are waterproof. The camera is activated via the reverse light, but also wired into an accessory switch so it can be manually turned on via an upfitter switch in the cab. There is a 60V 5A diode between the backup light and the switch so power does not feed back into the light when the switch is turned on.
  • Every aftermarket stereo brand offers a large touch screen interface with backup camera input. I like the Pioneer BT2600. Lots of backup cam options from $15-500. How about a license frame mounted one?
    Edit: Sorry, that model no NAV.
  • We have a Kenwood in our van that I put in probably 6 years ago. While we don't have a camera, it has the function available. It is a Garmin based Nav which I really liked. We have been very happy with it.
  • Pioneer or Kenwood are both great, Alpine is as well but can be a little NON user friendly. Kenwood's GPS is Garmin based and works well.
    Crutchfield isn't always cheaper. By the time you add shipping and the installer most likely charging more because you didn't buy from him it'll be a wash.
    And if it has to be removed for a warranty issue, they'll charge too I'm sure.
  • donn0128 wrote:
    Buy a portable gps and mount a backup camera that can plug into the gps. Much cheaper that way. Garmin makes a variety of units with camera imputs that work slick
    went this route. Wireless BC-20 back up camera and Garmin RV760LMT
