kennethwooster wrote:
After a lot of rv net searches, and internet I finally went with Goodyear Wrangler AT/S. I could still change my mind, but hopefully these will do the job. My trailer , Cameo,31 ft. is pretty heavy for SRW. The Michelins that came on it carried the load just fine, but wore out at 26000. Thats the only 20 inch Michelin makes. I guess my main concern is will the Wranglers handle the load. I do need a stiff sidewall.
The Michelins LTX 2 are a 60k mile rated tire. I've read that Michelin will pro rate these tire and apply a discount towards another set of Michelins so maybe an option to consider.
I'm in the same boat as you since I'm at 21k miles on my 20" Michelins and I'm starting to look for my next set of tires also. I'm also looking at the Wrangler AT/S E rated tires myself and they should be equivalent to the Michelins, but I'm on the fence with several brands at the moment.
