raychris1's avatar
raychris1
Replace/repair aerolite floor or junk it?
We have an 1997 Aerolite 25rdb TT. It is an ultra-lite. It has not moved in a few years. We used it for storage of extra stuff. I decided to clean it out and get it going again. I started emptying it out and discovered that it had apparently leaked thru a roof vent. Gunk had pooled in one of the lights. I also discovered that the floor in the front end had gotten very soft. We had previously repaired a leaky bathtub fixture. We had to cut an access panel in the sidewall because the access hatch for the tub was on the side of the tub and the hookups were halfway up the wall. I thought we had fixed the problem but there must have been another leak somewhere. I am trying to decide if we should attempt the repair or just junk it. I know the Aerolite (especially our era) TT have a bad rep for floor and frame problems. My question is...does anybody have a well documented floor repair/replacement video for guys that have some at best average repair skills. Or should we just junk it and try to get a decent older TT.
  • We replaced the front and rear floors of a foam built piece of garbage lightweight camper. Major job. Fixing a roof vent is nothing. Floor damage on a foam floor is a nightmare.
  • raychris1 wrote:
    I can definitely say we will not be fixing it. ....Time to talk the wife into a new rv.
    I was in the same boat last year. We had our Jayco for 11 years and found a significant portion of the rear bunk area floor was rotted. The cause was a cracked elbow of the hot water line feeding the tub that had gone unnoticed.
    I've fixed just about everything around our home and have also done an RV floor replacement. I finally decided between my busy schedule and lack of time to even complete the small things on my ever growing to-do list that tackling a massive floor replacement project was not realistic. We found a buyer that had plenty of time to do the project and bought our 5th wheel. It was a long overdue upgrade so it worked out fine overall.
    Here's one option for you: remove and sell all the good components (fridge, water heater, furnace, etc), sell the aluminum for scrap, then strip it down to a bare frame and and axles. Now, you can install a deck and use it as a utility trailer or sell it to someone else for the same purpose.
    KJ
  • Well, we decided to get rid of the Aerolite. The wife wanted to go back to a tent trailer. We ended up getting a 2001 Coleman. Older than we really wanted but looks to be in great shape. Our maiden trip is at the end of this month.
