mgirardo
Oct 06, 2019Explorer
mrstan64 wrote:
I am looking for a local to MA or NH to replace my 21 ft TT floor due to it becoming spongy.I have attempted to do this on a local area of the trailer, but I found many other soft spots throughout. Does anyone have any recommendations?
Mark
I don't know anyone in your area, but as others have said, it will be costly.
Our Hybrid TT had a soft floor from a leak at one of the outside storage doors. Factory didn't seal the bottom (have seen that on lots of TTs and MHs) and water came in. It started under the dinette, so we didn't notice it until the rot came out beyond the dinette.
I ended up replacing about 40% of the floor. Ours was an ultralight and after making the fix, the floor was not as stiff as new. I ended up putting in a few 2x4s to act as I Beams between the main trailer supports. It helped, but still not as stiff as new.
The process was a long one. I had a friend help me pull the furniture up (sofa, dinette and the front storage cabinet). We also had to remove the pump, fresh water tank and the hot water heater. We just the vinyl floor and pulled it back as far as we could, which was to the refrigerator. There was a small amount of rot under the refrigerator, but it wasn't bad enough to warrant removing the pantry and refrigerator cabinet.
After we removed the rotten wood, I let the trailer sit for a week in the backyard with the bed ends out and the door open in the middle of the summer in GA (no rain all week) to dry out. Then I replaced most of the insulation (foam board) and I used 1/4" oak plywood instead of luan. Glued the floor back down and replaced everything we removed.
-Michael
