DiskDoctr
Jul 31, 2014Explorer
Shouldn't be any problem. I'd recommend replacing your valve stems with higher rated ones, though. The lower ones tend to leak more air over time than the higher ones.
Etrailer.com has them, just get the length and diameter you need. Call and tell them what you have and they will help you select. Hint: the smaller diameter fits passenger vehicles (non-commercial)
You are likely to be floored at the improvement under load with the stiffer tires. I now have 10ply on my 4Runner (60 psi empty, 70 psi towing) and it is rock solid, even near the max tow rating and 60-70mph.
44,056 PostsLatest Activity: Nov 19, 2013
